Black-Demon
You don`t mention any uprated injectors, extra fueling or reprofiled cam of any kind. If you are still fueling though stock injectors you are the first person i have ever heard of to go over 230ish bhp no matter what size or make of turbo fitted as you run out of fuel to produce the power no matter how much air you get into the engine.
Yes, it´s true. I don´t have any injection upgrade or reprofiled cam... Those hardware parts are OEM...
The OEM injectors (with the right ECU Remap) are more than suficient... With this large turbo (seems bigger and produce more HP than a GT25v / VNT25), and runing with the 1.95bar that I have mentioned, the black smoke is there... A lot of black smoke...
With 2.3bar (between 3000/3500rpm (peak) the smoke desapears... So, if we could make a turbo with this specs and that handles 2.3bar saftely, we could probably make 260Hp...
In tests, on a MAHA, with this turbo, we made 256Hp, but it was not safe to the turbo...
Maybe next week we have some test here...
. I have met Miguel when he was over in England before. Next time you see him tell him to get his little ass back over to Allard's in England so he can do another better map for my car as i am still running the same map before i had propane and NOS fitted.
