cutting a coil in springs
chris27
169
Dont do it. Very dangerous. Springs are progressively wound (ie compress differnet amounts depending on weight). Keeping it simple imagine that half the spring compresses under half a ton and the other half compressess under a ton. If you cut it in half you are loosing the first amount of compression, so with between half a ton and a ton of weight on it, the spring will do fu*k all.
If ive got that completley wrong someone feel free to correct it.
Dec 17, 2006
1,837
Bristol
Also the ends of springs are wound flat; i.e. it forms a circular contact at each end with the strut. Cut springs will just leave the end of a coil in contact with the strut. Not a good idea!
chris27
169
Or jus buy some lowering springs rather than coilys if your on a bit of a budget?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
out of all the types of spring i have ever come across only one type (tangential) is cuttable in any form and doing so increases the spring rate anyway so needs some serious maths/measurements and understanding first
the top of ibiza springs are pigtailed but if i remember the bottom is tangential so theoretically it is possible but and i MEAN BUT considering the time/effort/calculations and lack of multiple pieces and test equipment to verify results you may as well buy some lowering springs :):) be a lot safer and simpler
the calculation is (11,250,000 times the wire diameter to the 4th power) divided by (8 times the active number of turns times the mean diameter cubed)
then on top you will need some shockers that operate correctly to match the new spring rate/length as your standard ones will just bottom out on the first corner pothole and put you in the wall :)
silverline1
christ, some folk take stuff for gospel
Polo suspenson wont fit, its not weighted properly
if you are going to do anything, do it properly or not at all
orangemuffin
i love you all.......
Sep 24, 2008
1,747
yesterday
Cuting springs is very old school. People use to do it alot when i was at school to ford orions and metro's that they brught for £150. The ride is truley shocking and is very dangerous.
May 31, 2008
1,247
Haha i remember my mate wanted to cut his springs on his saxo, i told him bad idea. Just get coilovers £200 from club polo, is nothing if you think about it.
OllieL
2.0 16v Cupra Sport GTi
Dec 10, 2006
1,868
Birmingham
Another cheap way of lowering the car would be to fill it with much weight as you can.
Paving slabs normally fit well into the front foot wells, and you can fill the spare wheel well with concrete
Ollie
