No, P0030 and P0135 are both for a fault with the front O2 sensor, which is the one before the cat. That sensor is responsable for the fueling mixture of the engine..... It's quite possible that the wiring to it was damaged when the cat was removed. That would be the first thing i would check before you go to the dealer.
Chances are if you can find the problem on that, than the EPC code might be sorted too, judging by the thread i linked you too above.
I would disconnect the battery before you start looking, just to be safe, as i've heard cases of the O2 sensors shorting out and frying the ECU at the same time.
The P0420 code,cat below threshold is related to the decat though and nothing to worry about as such.
Sorry for taking so long to get back to you! The cat was removed about 2 years ago yet the EPC fault is about 6 months old, could it really take that long to make an impact? Could that also be a reason for the car completely cutting out and battery light illuminating?
