Damoegan's OLD Mk4 Ibiza Cupra, GTX3076r, forged engine reubuild
ibizacupra84
I have got a geniune VW/Seat 4.0 bar fuel pressure reg £18 posted
ibizacupra84
hi just woundering if anyone can help me on this i been looking on ngk pathfinder and just woundering if anyone has ran NGK IRIDIUM SPARK PLUG IFR6Q-G IFR6QG Stock No. 5648 and are these the right plugs to run on a BBU engine ??
ibizacupra84
well a few update
the car has had a full service oil/ filter, iridium plugs, fuel filter, gearbox oil changed
Full set of EBC slotted disc front and back with EBC redstuff pads
Vmax drop links
next job is to replace the turbo to mainfold gasket as it started to blow a little i'am not looking foward to this as it looks a pig of a job to do :(
ibizacupra84
time has come to sell Ibiza cupra anyone who is intersted it is for sale for £5500 and will have 12 months mot and tax till 02/2011
ibizacupra84
time for some upgrade to the engine, the turbo had gone and also it had a little miss on idle and when you started the car up from cool it sounded like they was a f**k tappet, so i took the turbo off and got it recond so it brand new now, i also took the head off to find that they was two melded pistons :(, so i took the pistons and conrods out and found and very **** quite conrods the mating surface between the conrods and normal machined flat the ones i took out looked like they had been snapped apart :(
so engine rebuild in need so i be getting
Stage 1
New forgod conrods with forged pistons
new main, big end and thrust bearings
new oil pump and chain
arp main stud kit
baffled sump
AEB large port head with inlet to suit (head has been fully rebuild with new vavle guides, stem seals, and the all the vavles have been lapped in).
Supertech performance Vavle kit
Arp head stud kit
injectors (havn't deside on cc yet)
bosch 044 intank fuel pump
stage 2
Gt3076r with tubalar mainfold and downpipe.
melted piston
photos of shocking quailty conrod (surely they do not come out the factory like this) all of them are like this
AEB large port head fully rebuild ( will need to fit the Supertech performance Vavle kit when i order it)
reconded turbo
i have just orded conrods and main big end and thrust bearing so i will take photos and updates as i go along
ibizacupra84
yeh mate i have deside to keep it :D it was quick how it was but it should be even quicker one i finished with it :D
ibizacupra84
forged conrods and main bearings and thrust washers turned up the other day
ibizacupra84
My Recond K03s turbo for sale £375 ring me on 07824666202 if you are intersted
