Dash buttons
Haggistech
63
in the centre console where you have the heater controls you have the button fo A/C and another button i think is recirculating air
but when i push it in it just pops right back out does not seem to do anything
is this right?
seattolsports
You are correct it is recirculating air but it should not pop out. It should feel the same as the A/C button and light when pressed in. I never use this function as it causes the windows to steam up.
seattolsports
on on a click switch. one push on and one off. You can check but you need to remove the dash cover that shields the ac controls etc. The button are on the buttom of that assembly. You can pick the whole section up on eBay. Does your ac work etc? one of the other things to concider is the fuse for that circuit. I remember when my fog switch went on my rover it was the fuse. same type of switch....?
Haggistech
63
when i push in AC button it stays in and lights up
Recirculating button comes back out and does not light up
l18oud
my air con some times goes on then when i release it goes off my mate has a leon that does the same ??? i thought it was the air con running out but now its been working for a week
seattolsports
The aircon gas does not affect the buttons however it does seem to be a very common fault. Try replacing the buttons if you can find a set of if not I will dig out the part number and you can order from SEAT (Remorgate time)
Sam20v
949
Dubai UAE
Sorry for bringing a relatively old thread back up, but doesnt it also depend where the breeze is set to blow.....i am sure in my old tolly if it was blowing in the car towards you, you could have it on recirc, but if it was set to the windscreen the button would pop out as it would only allow air from outside...
if your dial is set to the windscreen it may answer the question why it wont stay in......
