davecupra16v
Anybody know how to change bulbs in the dashboard where the speedo is? one side on mine is out and i dont know how to fix it, its a mk2 beeza.
cheers
dave
hi mate, unscrew and remove the plastic surround around the speedo. then unscrew the speedo 1 each side (use magnetic driver). pull unit towards you and tilt forward. you will then see the led's. they simply twist in... i believe they are 509t
