changed one on mine its just plug and play six bolts to remove lower the glove box onto the floor if you undo the wire that goes to the airbag switch the one with the key hole in it then DO NOT switch the ignition on as it will throw an airbag light on the dash the motor itself is held in with two or three tiny little torx screws which can be a bit awkward to access i changed mine myself it cost around £80 from SEAT for the motor and took less than an hour to remove and refit a new one
