Defrost flap control motor
Larahausp
16
Hiya
The windscreen defrost blower is not working on my exeo. My friend has put it on his machine and its come up blocked or no voltage.
If I change the motor is it just plug and play or does it need to be plugged back in to be .reprogrammed
S70DGE
135
14
Halifax west Yorkshire
changed one on mine its just plug and play six bolts to remove lower the glove box onto the floor if you undo the wire that goes to the airbag switch the one with the key hole in it then DO NOT switch the ignition on as it will throw an airbag light on the dash the motor itself is held in with two or three tiny little torx screws which can be a bit awkward to access i changed mine myself it cost around £80 from SEAT for the motor and took less than an hour to remove and refit a new one
S70DGE
135
14
i think you need to unplug it or sit the glovebox on top of something in the footwell i.e a box or something but its easier to unplug it then put the glove box on the footwell floor it gives you better access as long as the ignition is off and the keys are out then its safe to unplug it
