Design 90 Wheels?
JamesE
157
Hey Guys and gals,
Ive just bought some design 90's in 6 and 8 inch with a 52mm offset in 16's,
What other thing would i need to get them on my cupra im a bit new to this so any help would be greatfully recieved!!
I know i need hub adaptors and thats about it so which ones and what else do i need?
James
I also have 2 7.5" design 90's which im lookin to sell so if anybody wants more info on the PM me
Dec 13, 2006
724
Ashford, Middx
Fk adapters are what i bought. I got mine from venom motorsport, thought it would be safer to get a new set on there.
I've got 7j fronts and 8j rears and bought 20mm adapters, i dont get any rubbing but it depends how low you go.
You will need to buy some new wheel nuts as your standard ones can not be used for the d90's. They need to be m14 x 1.5 and have to be radius seated. The length all depends on what spacers you used, i think mine were 23mm from the bottom of the thread to the collar.
PM a price you want for the 7.5j d90's. But if i was you i'd put them on the front.
Hope that helps :)
JamesE
157
Thanks for that mate very helpful, so u put 20mm spacers all round? wont the 7.5j rub on the front?
James
Dec 13, 2006
724
Ashford, Middx
Yeah 20mm all round, still looks like my front wheels stick out further than the rears though.
There was a fella on here with 8j all round. All depends how low you go and what tyres you've got fitted.
JamesE
157
Cool so what size tyre would i need 2 get for the 6 and 8 inch wheels so there not stretched but look good lol because the 50mm wall looks poo!!!
James
Dec 13, 2006
724
Ashford, Middx
I have 195/45/16 on my 7j rims which is a slight stretch and then 205/40/16 on the 8j rears which again is a slight stretch. I dont think the tyre walls are stretched too much to be honest. Have a look on the 2nd page of my project thread theres a few close ups of the wheels.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
You'll need atleast 20mm spacers (or hubcentric converters or whatever you call them in english) as 52mm off set is 17mm change from stock (more to the inside).
As for the front being 6J, don't you think they are very skinny? And getting your 211hp on the road on those little tires might be difficult. WHy not put the 7.5J with either 205-45-16 or 195-45-16 (little stretch) on the front and the 8J's on the rear?
Jan 8, 2007
2,958
Wiltshire
That's what I'll be doing with mine :) 7.5J up front and 8J rear
I'm thinking of running 20mm adaptors up front and 30mm on the rear but not sure if the extra inch on the back may push them out too much
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
seems to me when running 8J rim, which is already quite wide, a 30mm spacer would really push it out a lot, if not too much
JamesE
157
Thanks for the input guys i think id get 25mm for front and rear should look ok then.
why do you have 40 profile on the rear and 45 on the front IMGAUCI
doesnt stretching the tyres make the handling worse?
James
JamesE
157
What sort of price do you guys think the 7.5j would be?
They have just been powdercoated in satin black so in good condition just been sat in the bloke i bout them offs garage for a little while.
James
matsportline
140
put the 7.5's on the front with a 20mm spacer and a 195/40/16 tyre and put the 8's the back with a 25mm spacer and the same 195/40/16 tyres happy days won't rub give you enough stance!
Dec 13, 2006
724
Ashford, Middx
James
I was looking at the overall turning radius of the wheel and tyre. Because the rear wheels where bigger and i didnt want to stretch 195/45/16's on it i went for the 205/40/16's. When calculating all the tyre profiles this had the smallest difference compared to standard.
Hope that makes sence :blink:
alan_n
79
Uxbridge, West London
With the 7.5J rims, i believe they only came in 65mm offset, so you would need quite a large adaptor. I may be incorrect, but this is what i found when i had a set for my cupra
JamesE
157
Yeah the offset is 65 on the 7.5j thats why im goin 6j on the front because ive already bought the 25mm adaptors... so im not sure they would look right.
James
JamesE
157
Hey guys do you know what the size the hex is on the standard bolts as i want to try and get the same ones for the new wheels?
Im gauci what size hex have you used?
James
