cupramat
45
Can any one tell me wat the LCR has different to the LC engine wise?
n wat can i do to my LC to get the same 225bhp as the LCR,
i have tryed searching on the site but couldnt find anythin about it,
any help would be nice.
different turbo, injectors, maf. totally different.
lc to lcr power = stage 2 custom map with supporting mods.
1. full turbo back exhaust
2. induction
3 uprated tip
4. uprated dv
5. possible 4 bar fpr
6. possible fmic
that should see you for 230ish bhp.
but... the lcr handles better as stock, and has brembos aswell.
cheers for that mate u r a big help, i new to all this so dont know wat all the uprated tip, possible 4 bar fpr, and possible fmic, mean, sorry to be a pain
cheers
tip = turbo inlet pipe, from the airbox/maf to the turbo. the oem is restrictive. have a look for forge tip on google.
4 bar fpr is 4 bar fuel preesure regulator, oem is 3 bar, 4 bar for extra fuelling
fmic. front mount intercooler, lc has 1 side mount, lcr has 2 side mount intercoolers. fmnic allows greater cool air flow
have a good search on this forum for the above abbreviations... wealth of info
cupra r is 20mm lower as standard ??
LCR 20mm lower than a standard leon
LC 10mm lower than a standard leon
When i was looking all the spring makers quote against the standard leon. so if they say a 25mm drop on an LC the reality is it will actually drop 15mm
2. induction
3 uprated tip
4. uprated dv
6. possible fmic
Aren't you just better off selling yours and buying a real LCR? Suppose it depends how much your LC is worth though.
Until you notice that most modded Lcrs have changed their suspension set ups. I think a set up lc would handle better than a stock lcr.
Depends what you want. go above 290bhp and both cars need the same mods to make the power.
From the August 2003 SEAT Leon catalogue:
DIFFERENCES OUTSIDE THE ENGINE BAY
  • LCR only had black roof lining (Cupra only came with white)
  • Paint wise the LCR had the options of Ebony black whereas the Cupra goes Black magic metallic
  • Cupra had factory option of cruise control, LCR didn't
  • Cupra had factory electric sunroof option, LCR didn't
  • Cupra had factory option of leather upholstry (electric), LCR didn't
  • LCR had factory option of Tracker Retrieve (in 2003), or Smartnav (in 2004)
  • LCR had 18's 7.5J, Cupra 17's 7.0J (alloys)
  • LCR had 4 pot Brembo's, Cupra had OEM single pots
  • LCR (obviously!) had R styling pack
  • LCR had ESP & EBA as standard, it was only an option on Cupra
  • LCR had ventilated discs on the back, Cupra had solid
  • LCR weighed in at 1376kgs, Cupra at 1306kg
  • LCR belched out 211g/km of Satan's black wind (CO2), Cupra 204g/km
Performance wise for the petrol variants
LCR: Max 225PS (at 5900rpm), max torque 206lb-ft (at 2200rpm)
Cupra: Max 180PS (at 5500rpm), max torque 173lb-ft (at 1950rpm)
