Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
No no
Sorry if you dont understand this lol.
They are simply wired up
3 wires leading to 3 switches,
1.driver window switch
2.passenger window switch
3.automatic lock from inside switch..
They are clipped into the underside of the door card which you cant see.
To get the door card off, simply wedge the plastic handle bit ( they are usually scrapped/worn) Then there are 3 main screws..
Then the bottom right corner, wedge that out
The door card should drop but will be held on with the wee driver nipple/ thing. ( its the bit that moves up and down when u lock the doors )
have you tried spraying a lubricant on it?
my drivers mirror (big one) folds in, but i darent try the stubby one!!
hi mate, do you mean the bonnet bra lol?
i don't know how hard it will be but i think you can take the mirror and then you be able to see if theres a hindge or not underneath that
Two hours later and they are free as a bird! Easy movement, no grinding.
you lot arnt sad enought that i have to take a picture to prove they fold...do i ??
