Doing this Mod would you not have to have the EGR turned down by VAG-COM?
If so I would be up for this Blacking Plate as well
Post 04 cars: THE EGR CANNOT BE TURNED DOWN OR SWITCHED OFF THROUGH VAGCOMDoing this Mod would you not have to have the EGR turned down by VAG-COM?
DOES NOT GO INTO LIMP MODE MATEY YOU JUST GET THE CEL LIGHT ON.no.. but it can be turned off aswel using vag.com.. the vacuum pipe on the up of the egr may need to be disconnected and blocked off as some car bring up an emissions fault depending on the ecu/year etc and therefore goin into limb mode,
removing the pipe will solve the limb mode problem
does the 5mm hole in the blanking plate not sort this problem??DOES NOT GO INTO LIMP MODE MATEY YOU JUST GET THE CEL LIGHT ON.
Glynn
On post 04 cars yes it does.does the 5mm hole in the blanking plate not sort this problem??
No.I run a Seat Leon FR Tdi 04 plate, I have disconnected the EGR pipe and yes I get the Yellow CEL light on which I can remove with the ECU reader but it's a pain doing it every 20 miles or so!!
If left would the light turn off and just leave the code in the ECU?
Cash tight at the moment due redundancy so mods are not a priority at the moment, that's why I thought of VAG-Com and some kind and understanding person to do it for me.
Although car already chipped, lowed, uprated brakes, cold induction kit, and a full Milltek System so one can not complain!!!
