Does anyone know where I can get this intake feed I can't find it anywhere
epts2008
rule the bends
Mar 19, 2009
280
Chelmsford, Essex
Found this intake feed kit on uk mkivs and it is apparently an exact fit to my 1.4 leon but I can find the feed kit anywhere apparently its an OEM part :S
any help would be greatly appriciated
thanks
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
do a pic pointing out the part you need - or a leon pic so i can see the difference
if you can tell me the engine code would help me look it up
failing that if you know someone with one - the part number will be on it :):)
epts2008
rule the bends
Mar 19, 2009
280
Chelmsford, Essex
unfortunatly I dont know anybody with the feed and I also dont know the engine code it comes with I want to put it on a AHW engine which should take it as it looks the same from the end of the redline on the image I have highlighted in red the parts i need
this is what the engine looks like without the air feed
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
5 1J0129752 intake manifold
(7) 1J0129594F control box / for vehicles with manually regulated heater (on yours at moment)
(7) 1J0129594G control box / for vehicles with air condit.
8 1J0129618 air pipe / for vehicles with electroni- cally regulated heater (on yours at moment)
as #5 seems standard it appears to be #8 that decide which type is fitted and as you have #8 it would appear your car is (vehicles with electronically regulated heater) rather than air conditioning which is whats listed and appears in the pic you listed
rest of it is in diagram below
19 1M0805971 air duct
as always though it would be worth taking the time to find a car with it on and confirmt all the details with a dealer prior to order as the ones i list may be out of date etc
