Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Forbez said:There are the writers of Vag-Com, and they occassionally check the VAG-Com section, try sending -Uwe- a PM asking him if he can help.
Here's his profile:
http://www.seatcupra.net/forums/member.php?u=809
Forbez said:Alex, whats the number for the error codes that are coming up?
bbsboy said:I had a prob with mine last winter which sounds quite similar to the probs your having, a slight missfire and a hesitation, turned out to be a bad earth for the coilpacks, try cleaning the contacts down and see if that helps
Steven
Wermy said:hey alex, was just speaking with my college at work about the problem with your car, i showed him your first post about the problem and he recons it could be something as simple as blocked injectors or poor air intake.
He's asking if you have uprated the engine in any way and that you could need bigger / more powerfull injectors.
He aslo recons he made up that seatcurpa.net numberplate for you few months back b4 your show.... what ever that means.
ben
ben
David_smith_909 said:i thought alex's car was standard?? wont need bigger injectors
CupraTgirl said:It is standard, although i have a Forge 007P![]()
David_smith_909 said:you dont need bigger injectors then, unless one of them is blocked![]()
CupraTgirl said:The engine is standard!
Really? Does he work in Halfords?
CupraTgirl said:Ha ha! Its a small world
The one in Woking?
Wermy said:Yup, did the plate look good on your car? any pictures?
