ads_uk
27
Leicester UK
Hi,
has anyone installed this kit?
Seems to indicate on the page it's aftermarket? Interested in fitting to my 2.0 150 Ateca (Front wheel drive).
However they state there are no fitting instructions.
Anyone done it on the Ateca?
thanks
Mine came fitted. I guess the mount points are under the carpet, pre drilled out. You would have to investigate what is showing if you pulled the carpet up before buying it if you want to be on the safe side. Suspect the facelifted ones kept the same design so you could eyeball them or any secondhand ones.
The boot was always a preoccupation with owners since they got deals but you couldn't specify the options to change it to something else. They were not on parts lists at the time. Some people made their own wooden floors.. ...
You can generally have fun working out where parts go from here:
Might be an old catalogue
Leave the rest to you. Once I looked at it and you needed the side mounting stuff which it sits on, since they say bolts they must be supplying it so the question is pre drilled I suspect and how much of the rest of the car you need to take apart. A look may resolve that.
