down and hella flush k1 new killer adjustments to the interior say buy to plastic
Jul 9, 2012
523
Here is a spec of the air setup I will b running
-Front and rear airlift XL slam airbags and dampers.
-Autopilot V1 and all necessary cabling/manifolds etc
-3/8 airline version
-Twin viair 380c compressors
-5 gallon tank
-2x accuair water traps
-2x upgraded leader hoses from plush
-175psi pressure release valve
-Tank drain
-New airlift rear airbag
- New 5 metres of 3/8 airline
-Tank is carpeted and includes a carpeted false floor which fits in the Mk5 perfectly.
Jul 9, 2012
523
Ok so start gettin the compressors tanks and management in the boot its going quite well so far got everything in place and screwed down gunna need to make a false floor yet and run all the cable and the cabling looks as easy as wire up a sub but at least it's all mounted
Tank will b changing soon to either an anodise red one or tuna do it in white leather with red stitching not too shore yet
523
Ok so I have started to run the air lines through the k1 and remembered that the interior is gunna have to come out to make my life easier so striped everything out
After that it was time to start running the lines from the rear to the front
Passengers side first
As you can see the power for the air being run too all under the carpets of the car as I don't want to have to worries about catching the air line whilst driving
Now the air line is we're it needs to b just need to drill a hole to get the line into the arch to connect to the bag
Now drivers side
Didn't take as many this side as I didn't think you would wonna see too many of the same pics
Now as time to run the cable to the control panel go the management once again under the carpet it is as I'm going o mount the control panel under the head unit
Control panel connected once the centre console is back in i can fabricate a bracket for it and box it in ready to b trimmed
Roughly we're it will sit wen finished
Will up date tomoz if the snow doesn't settle hopping to have the bags on and connected so can test for any leaks
Jul 9, 2012
523
So after done blood sweat and almost some tears I managed today to get the rear bags done and working
This is how it sits roughly
Also had a look at the Clarence n I can drive like that if I want
Now the bad bit after 4 hour of beat the hub with a rubber mallet as not to damage anything I managed to get one coilover off so will b out there 2 moz hopefully to get the rest done
Just need to get the front shock n bag in but it's a ball ache lol
mini_racer
59
Your car is awesome mate wish mine was half as clean hats off to you! Air ride looked bang on aswell can't wait to see the fronts on good luck with them.
