cupraR59
153
grimsby
hi there iam new on here
does anyone else have this problem ? my downpipe bolts keep coming loose no matter how hard i tightend them :( it a miltek dp btw any help would be appriciated thanks guys .
Try fitting some new washers, get them from Seat/VW tho, as i'm sure there made from thick soft material, which helps the nut bite and stay tight :)
Come to think of it, i've got a few spare washers if you need some.
Double up the nuts. The second nut locks the first nut, this will also make it easier to remove later on as rust wont be able to build up as bad ;)
thanks guys doubled up the nuts as calum cupra suggested ;) and lock tighted em as well
if they come loose again iam guna weld the :censored: things. and thank you ez tutty for the kind offer .
