Downpipe and decat only has one o2 sensor hole
Graham1984
19
Have you got Vcds too? I'm guessing you will still have to turn off the light after fitting the extender too.
Bouncerbeater
Old enough to know better
Mar 15, 2013
1,303
Gloucestershire
Yes you will need to reset /clear fault codes after fitting the spacer then hopefully your eml won't come back on. Assuming you've sorted your pre cat sensor too of course
Graham1984
19
I can't believe how cheap Vcds is either. Very handy bit of kit really, especially compared to the normal aggro of visiting a garage etc.
Graham1984
19
For anyone else reading I believe as long as it has- M18 x 1.5mm as the fitment, it will work.
