Driver window dropped. Help!
g60stu
420
311
Reading
my driver window is stuck fully open this morning. I’m in the process of taking it all apart.
Do I need to remove the window regulator from the metal door card to get the door card off completely or does the whole card plus window bits come off in one piece??
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,199
1,038
Kent
The motor doesn't have to be removed from the regulator but I like to as it gives you the ability to slide the glass up and down freely if you've already disconnected the power or switch.
Sent from my SM-G960F using Tapatalk
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
I can see you've already unbolted the regulator panel from the door, have you removed the 2x glass clamps though?
g60stu
420
311
Reading
Motor disconnected but I’m in a whole state of fubar. The glass is at the bottom and even when I had power the sliders are in the boottom position. Should the whole card be removable with glass in situ??
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
Ok sounds like the actual regulator is ******.
Basically you need to slide the glass to high enough to access the 2x 10mm bolts clamping the regulator to the glass through the black rubber grommets.
Once undone (not fully removed) you then slide the glass out of the door opening and away from the car.
Once that's away the regulator panel will come out completely apart from needing to disconnect the door lock mechanism wiring harness.
Reactions: bigT's lcr
g60stu
420
311
Reading
Ok. I’m making progress. I drilled out the speaker rivets to access the glass. Glass pushed up and selotaped to the door frame. Just trying to get the door lock wiring connector off and then the door card is free. What a ball ache!!
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
Shame you weren't closer, I can remove these things so quickly now.
g60stu
420
311
Reading
Door card off. The glass mounting bracket on one side snapped in the process.
Motor works fine, so I assume this bit is busted:
What are the best options? Do I just get an aftermarket on from ECP or should I be considered genuine £££??
g60stu
420
311
Reading
How much and how quick can you post is the question? And is it wise replacing something like this with another 15yr old part??
hilly81
265
43
Little Sutton
I replaced one of these on my old Passat. Not difficult to do but ridiculously fiddly to do right. Getting the correct tension etc. I almost gave up. My advice, allow plenty of time and be ready to persevere.
Thai-wronghorse
Dec 3, 2015
2,199
1,038
Kent
You can buy repair kits but for the cost, time involved and amount of faffing around I'd always opt to replace the complete regulator carrier panel.
Many aftermarket ones are **** and / or involve drilling the rail rivets out.
Far too much unnecessary effort imo.
I sell various regs weekly and never had a problems with used ones.
Its normally obvious if its damaged in any way or the cable is looking fragile.
I sent these 4 out on Wednesday as it happens.
g60stu
420
311
Reading
Temporary repair done. Glass selotaped up and Sainsbury’s bag for a water seal:clap:. @Thai-wronghorse is sorting me out with new bits.
Later I’ll post up some post mortem photos of why the old regulator failed.
Phew!! Time for a tea break!!
Reactions: Legojon
g60stu
420
311
Reading
New door card installed but I noticed the some reset/calibration is needed. Currently when the window is closed it comes straight back down afterwards (like the safety feature if someone stuck their fingers in there!!).
Anyone know what the reset procedure is before I start googling a whole load of old wives tales and misinformation??:doh:
g60stu
420
311
Reading
Ok. After much searching forums I was none the wiser. There are instructions in the user manual to reset the auto and rollback functions but these didn’t help.
The behaviour I had was
1) auto down worked
2) auto up didn’t work
3) manual holding the button to close the window caused the safety rollback to kick in just as the window got to the closed (resistance) position.
What did work for me was just pulling the window regulator connector out, cutting the power, with the window in the closed position. Then I performed the procedure from the user manual - lock the door with the key, lock again but hold the lock position for a second or two.
What went wrong initially? Well, I think that when I installed the new regulator, the position was set so that I could access the glass retainer clamps through the rubber grommets. This position would represent the window slightly open, so I think I connected the motor harness and the system powered up in the wrong position. Seems like you really need the window closed position when powered is applied to the motor. Kinda makes sense.
Now it all works! I love the engineering detail that goes into these systems.
