Model Year 22/23 Drivers side mirror replacement issues
May 15, 2025
17
I’ve just had my drivers side mirror(RHD) replaced as the previous one was ripped out by vandals. Trouble is, the only second hand mirror I could find was from a LHD formentor and I wasn’t aware that there was a difference in mirror characteristics, what this means is the mirror now shows a lot less of the road as I am not able to move it out enough and instead I see 75% my car and only a small fraction of the road. Is this something that can be fixed with a replacement mirror that is convex or will I need to change the whole module all over again but this time from a RHD formentor? Or is there another fix that I can do to resolve this which is a bit more cost effective.
cairus
1,673
588
Does the left-hand drive mirror have a memory function, meaning it lowers when reversing? If not, install the motor for adjusting your defective mirror.
May 15, 2025
17
I’ll be honest I’m not sure as my car doesn’t have a function when I put the mirror into R for it to dip as it’s RHD so when I put it into L the left hand mirror drops only. I also do not have the mirror that I am replacing as it was stolen so I do not have an additional motor to put into the new mirror
dazed
87
58
The drivers side mirror (RHD, not sure about LHD) is larger. I remember a thread about it a while ago, which made me notice it on mine. That's probably your issue. So I suspect the only sure solution is to find a RHD drivers side mirror unfortunately
