Was going to fit some coilovers tonight but fell at the first hurdle
I dropped a ball and rounded the alan key off just wondering if anyone had any ideas how to remove it without an angle grinder? i mean i will us one but will be last resort
It happens alot
Best bet is to take a wrench of some sort (best if the jaws are a little thin, a welders clamp is a wonderful item here) and just hold onto the side clamping against the strut (other side of the nut part) be carefull not to screw up the rubber keeping **** out of the Ball joint.
Else you could use a nut crusher, but they tend to cost some, and cheap ones are **** to say the least...
Otherwise just take and bite the apple, drop links a consumable, so their lifespan is limiter anyways, and it saves you to loosen them again
