You cant not notice a loud constant drumming noise coming from the front passenger wheel especially at 60mph or above. The faster you drive the louder it gets. Is it the wheel bearings?
eagle F1's?
run your hand on the edge of the tyre and feel for a "wavey" feel to things.
also, could be wheel bearing which may have some movement if you push/pull on the tyre
tyre swap from front to rear may move the noise if its the tyre
I have got a similar problem. Previous owner had been driving with the tracking out which had warped the tyres on the back. I would get them checked before you start thinking suspension or wheel bearing. But i have also had both front wheel bearings changed and the noise still persists because of the tyres.
have you checked wheel bearing,,,,,,,,,,,,as i said earlier i changed everything else to find out the wheel bearing was the problem,i,m only trying to save you the trouble of trying everything else for the sake of a simple check...
i thought you get a noise if the bearing are going as im not get any noise i havent checked that but when the car was up in the air the other day i gave the wheels a push and a tug and there was very little movment where if it is the bearings they would move more wouldnt they ? is there any other checks for bearings ? it has got its MOT next week so somthing may come up on that
hmmm, ruddmeister (i think) had something like this, it wasnt bad tyres it was something to do with the suspension i believe.
