sambryant
RoadRunner meep meep
Mar 26, 2009
4,845
Bristol
hi all. does any one know were i can get 2 new hoses. im talking about the hose from the charge pipe to the dump valve. also the smaller hose from the charge pipe to the n75 valve. its for a lcr.
also
forgot to say do the older type tips for the audi tt 225 fit?
thank you all
can't tell you about the tip but if you want a good condition OEM one PM me. For the CP-N75 hose just use 8mm silicone vacuum pipe from ebay. The CP-DV hose is 25mm. Dealer for the OEM one or get some flexible 25mm silicone hose from ebay I'd say.
thanks danny. the problem i have with my cp -dv oem pipe is, its too short, think its down to my tip. needs to be 10mm longer. dont really need the other pipe but if i replaced 1 with something upgraded i might aswell do both.
thanks anyway
thanks anyway
I have exactly the same issue.. I have a forge tip and find that if I connect the DV to the TIP first, the pipe from the CP is not quite long enough to get a full "grip" on the DV flange. Reversing the forge DV makes things slightly better, but I think I will end up ordering some 25mm flexi silicone at some point!
