Dump Valve
matt9238
got my cupra today
it has a recirculating dump valve on it
i want to get a noisey woosh woosh dump valve just to use not permanently
what shall i get?
matt9238
it has an unbranded induction kit on it
wat wooshy dump valve can i get
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
matt dump valves (atmospheric ones) will cause errors and send your car into limp mode, ie virtually no boost, virtually no boost means no woosh so either put up with the 20vt (mine makes virtually the same amount of noise as an atmo anyway) or sell it and buy a gti-r or glanza.
Dec 31, 2005
1,856
London
Matt, seriously do a search and you'll find loads of different opinions on dump valves and induction kits that work well together.
I have a forge dump valve and to me it sounds sweet not too overdone either
oz_borne
Return of the mac
Mar 31, 2006
77
Quedgeley, Gloucester
lol
Search wooshy wooshy and it explains all.
Basically if you want a loud dump noise you could possibly do the following.
1.install a forge 007p DV
2. remove airbox and smooth all the interior ridges out.
3.install a green cotton panel filter
4. remove offside wheel arch liner
5. remove the incey wincey air intake pipe from the arch.
6. install a new air intake (or just leave the box open and the arch liner out)
If you do this, you'll get this noise.....ptshh tweet
Alternatively you could install a Ram air filter which will give a louder noise too as the DVs noise will sound better through a cone.
Open filters which use oil to lube and stuff, tend to kill the MAF too.
Believe me mate, you'll want to research this mod before you go ahead and think you know what you're doing.
it'll pay in the long run
oz
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Nearly all filters bar the stainless mesh one use oil, just some are more oily than others.;) Open filters will lead to heatsoak but sound great.
Jamie R
Standard is the way!!
Jan 19, 2006
230
Hertfordshire
Any problems if you use the open filter in the winter months only?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
lol heat soak from using an open cone filter comes from the engines heat not the exterior temps...(not that summer heat helps)
why bother with a wooshy dump valve...the car doesnt use them and ull probably lose power, even if u dont notice it
