Am I correct in understanding that when I charge my hybrid battery from the outlet, my 12v battery is also charged along with it?
If this is indeed the case, then this changes things radically.
For what reason then was your battery dead one morning if the car was plugged in to charge the hybrid battery?
Well yes is the answer. Cupra's reply confirms it and I've checked it with a multimeter.
My car was not plugged in, it had been stood for 8 days (link here Car Dead) and it seems the rear passenger door was not closed properly. I never had an indication of this in the car or on the Connect app. All very strange I know, but I've had no issues since.
Just to raise this topic again, I'm getting 12v battery low issues (SOS and Travel Assist errors and unable to access the car via the app) and yet the hybrid battery is charged 3 or 4 times a week.
Not convinced the 12v battery is being charged (or charged enough) by the hybrid battery.
I am fairly sure the 12v is never charged from the high voltage battery, or even on the same circuit. Maybe worth plugging in the obd and driving around a bit and then seeing what voltages are reported.
You're right, the 12V (LV) battery is never directly charged from the HV battery. There was a diagram I saw on the Octavia Forum (same PHEV though) that was showing the LV battery charging scenarios:
- while charging the HV battery from a ch.station (there's a HV->LV converter that provides the 12 V)
- while driving (both on ICE or in EV mode)
Are you sure about the charging station thing?
Reason I ask is even with the wall charger plugged in, I don't see 14v+ across the 12v battery it stays at the 12.7 odd
If I start the car, goto ICE, boom, 14.2v - even when it's not moving, as long as the petrol engine is running, I see 14v+
With ev mode, if the car is moving I see 14.2/14.1, but not if the car is stationary
As I am sure everyone knows, you need 14.2 to 14.4 for bulk/dump charge and then a 13.4v for float/maintain. If you apply 12v to the battery you are just killing it.
I see what you mean; I never checked the voltage on mine.
Here's where I got the info from:
https://www.briskoda.net/forums/top...ft-to-e-drive/?do=findComment&comment=5684673
It's not clear for me what "Slow and Medium speed charging" means, since this PHEV cannot take more than 3.5kW. However, it is mentioned "Fast speed charging" is not charging the 12V battery...
But again: what is slow and fast charge on this car? Is it referring to the two charging speeds we can set (on Infotainment and App): Reduced and Maximum? You can try to measure while plugged-in, but with Reduced charge setting.
You would hope that the traction battery pack and the support 12V battery's charge conditions were both being monitored at all times during fast or slow (mainly traction) battery re-charging - or is this EV stuff still in its infancy as suspected.
It's a bit disappointing, because the PHEV technology is not really young anymore. And the 12V battery discharge seems to be a common issue especially among PHEVs, but not limited to those. I've seen quite a few "dead" 12V batteries - replaced on warranty - on non-PHEV models too.
There's lots of electronics on these "modern" cars and plenty of poor coding/programming - incorrectly managing the low voltage system...
I took the car to update and improve the performance of the 12V battery, perhaps this makes a difference in your measurements and that’s why charging from the wall does not charge the 12V battery?!
Have you gone to the dealer for updates related to the 12V battery?
I don't remember what update number it was. But this was due to the improvement and preservation of the 12V battery. Read about it on the Internet, other owners discussed it a lot on some forum.
My car 4 months old cupra leon hybrid same issue twice with 12 battery dead. 1st ime after a month they said I needed to drive car more and charged 12v battery for me. A month later same again car in garage 3 weeks this time. They said stuff running in background when car turned off is draining 12v battery. Cupra uk know about this they said and a software update and new battery this time. Picked it back up from garage yesterday so fingers crossed
In both external charging situations, be it AC or DC, the power invertor (JX1) that supplies the 12v battery is not really involved.
The AC charging function is controlled by it's own module (AX4), then, when using DC it charges directly to the HV battery without any input from AX4.
From experience, if there is charge applied through JX1 to the 12V battery whilst charging the HV battery, it's minute and not enough to maintain it for long periods of time.
Just to add my experience of a flat 12v battery.
Note: I have my fuse for the 12v power socket in the always powered posistion.
I left my Dashcam on by mistake for a few days, battery dead no central locking, my fault
I gained entry to drivers door with physical key.
Could not open bonnet catch due to passenger door blocking, made a lead to run power into the lighter socket needed a 15A fuse in it (blew 5 and 10).
hooked a 12v battery in and quickly opened the passenger door.
Opened the bonnet found the 12V positive post in the fuse box.
connected a12v Battery, car lit up like xmas tree multiple errors on dash.
Car in Park held brake, presses accelerator to floor until it clicked and then hit start, just to get engine to run.
Discconected additional battery, ( I waited as while to see how things settled) then as i reversed away the car dropped into EV, when i accelerated away forwards engine was running again,all errors cleared apart from a general EM warning light.
Drove around for a while 30min , returned home and next morning everthing was back to normal , no errors no EM light.
Hope this helps someone out its my first hybrid and its confusing compared to standard car when it comes to problems.
Just a comment as you mentioned not being able to open the bonnet due to the bonnet catch being blocked for safety reasons when the passenger's door is closed, Skodas tend to be same it seems which seems crazy, Audi and VW have the bonnet catch on the driver's side, so you can operate after using the key in the door lock to unlock that door.
It has been said on the Skoda forums, that you can yank the bonnet release handle out and up without breaking it - if you are desperate!
NO safety reasons there... only cost reduction!
Since most of the cars they sell are LHD (and the bonnet release is found on the "good" side for those cars), they simply don't want to spend an extra-penny to move that bonnet release on the right for RHD. Safety rules should impose to have it on the drivers side... but those are details for those guys only interested in profit.
