janowski1980
Platinum Grey
Dec 18, 2006
113
Hampshire
just bought Green stuff ebc brake pads for the rear as the factory ones are running low, will they make much difference. also will be adding them upfront when they run low. Cheers. SLC revo
As far as I thought the rears get very little use anyway, I doubt that you will notice a difference. May be a different story when you do the fronts though.
i just replaced rear discs and pads with OEM
they do very little anyway so dont see the point in spending more on them
fronts are a different case-ill be getting ebc turbo discs and green stuff when they need doing
I wouldn't recomend greenstuff for the front, they are not up to the job, but you should find the redstuff OK.
