I thought we boost slightly less in summer due to high temps so the ECU pulls back on timing and boost to stop detonation!?
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Pabs said:makes sense mate, but you call your valve a Greddy blow-off valve, or BOV.
In essence, it isnt a BOV is it? Its a DV or diverter valve.... could get confusing - i know it did when i read your message above saying you wouldnt use a BOV, but yet you already do......
Pabs said:yeh, agreed & understood...
but if yours is working as a dv... surely you should call it so ?
Just messin wit ya![]()
skem55 said:ive read this whole topic, and under the posts above wud i be right in saying try a bov and if it works it works but it may not. Still confused as hell whether too or not.
stu
dj_hektik said:Why? why not redirect the air back into the intake? do you really want the blow off sound so bad?
stu
Ruddmeister said:I think you are just about spot on, and I'll be as balanced in my reply as possible.....
- Your car was never designed to run a BoV, it was designed to run with a recirc valve.
- The HKS seems to be working OK as a BoV but it's £200+ (a recirc valve is £85)
- The HKS can be adapted to run recirc but that makes it a bl00dy expensive recric valve (probably better flogging it on ebay if you have issues)
- With a recirc valve fitted and the ECU running as designed your car is running correctly (i.e, in accordance with VAG tolerances).
The HKS BoV 'may' work faultlessly on your car, however nobody can guarantee 100% you won't have issues. Those issues 'could' be the car running lean (which is scary) or just cause check lights to come on, ECU will back off etc. Most people want their cars running quicker and better not slower.
However, on the other side of this argument / discussion a lot of people in the US have tried the HKS unit with success (and a few in the UK too) all with no sign of any 'issues'.
Who is right? - you decide.....
At the end of the day it's your car, if you want the BoV sound and you are aware there 'May' be a risk then you could try it..........if you want the 'safe' option go for a recirc valve and an induction kit or something![]()
Tallpaul said:what's the point in buying such an expensive kit to use as a DV valve?
It may perform faster better than a Forge 007p, but if you're on a stock turbo running sensible levels of boost then then the 007p with the right spring will do the job; These will last forever and you can pick them up used for £40.
The whole point of this discussion was people wanting the BOV sound.
dj_hektik said:Also another thing would be future upgradeability. If i want to change the turbo in future, I won't need a new DV. And it can be used on any other turbo car.
Tallpaul said:The point was you're not running it as a BOV. Still, it's very shiny.
You can buy the 1.8T specific HKS kit off eBay for around £200
http://cgi.ebay.co.uk/HKS-SSQV-BOV-...ryZ43120QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Kit is part number: 71001-KG001. The HKS SSQV is so popular in the USA that HKS brought out a kit for the 1.8T.
Alternatively you can buy one from ATP with associated bits.
http://www.atpturbo.com/Merchant2/m...OD&Product_Code=HKS-BOV-002&Category_Code=BOV
Every car reacts differently but most AUQ engines seem to be able to run them.
