"ECS HKS BOV Kit" Any expirience?
bbm
As far as length of time goes, mine was on for 8 months straight and thousands of miles, only pending code stored was for pressure leak, which you always get with a BOV, but no check light. Craig and v-g ran the HKS for well over a year and over 12k miles, same thing, perfect spark plugs, no check lights, VAG-COM checked out fine, v-g still has his on. Guy on Audizine well over a year and 10k miles with the Forge 004 BOV, VAG-COM logs show his fuelling is running within normal VAG parameters.
Beauty of the HKS, GReddy, etc. is that they can be re-circulated if needed, simple £10 adapter and it's re-circed.
same error code with BOV from bonalume ; after 4 months I have no error code ....because the BOV (i don't now why ) does not work anymore :(
Pabs
5,936
Basingstoke
as far as i know, there has been NO success running a BOV on a Cupra R.
It only seems to be the Cupra that works, and yet not all of them run it either...
dj_hektik
LEON 20VT FR
Don't mean to be a put off but I tried again to run my Greddy valve as a BOV.
5 psi limp mode in less than 10 mins. Reset the car, its fine for another 10 mins or so, then back to 5 psi.
Put the recirculation pipe back on and its fine.
But the noise is very addictive. I really wish there is a way to make it work, but im not too hopeful.
