Ecu help
Jan 8, 2008
528
Portsmouth
Anyone know it an ALH ecu would work on an ASV engine?
I have an ASV engine and a replacement alh ecu that has been de immobilised and has my custom map flashed onto it.
I've had it on the car but I get no power to the fuel system atall, glow plugs ect. The immobiliser delete worked fine and the immobi lights act as they should so I'm guessing the ecu is not compatible or there is a fault related to the other thread I made!?
Seatmann
Rough around the edges
Sep 16, 2010
5,568
9
Scotlanda
Why not try your other ecu back in and see if that works, it'll rule it in or out. From what I have found so far it seems to depend on the numbers, i.e. the type of ecu, not wether it was for an ALH but wether it's compatible with your car.
Is this a new problem now? The last one I read about was the car just losing a bit of poke or reving up when you pressed the clutch.
Jan 8, 2008
528
Portsmouth
It's not a problem tbh, my old ecu Is working in the car but I have been trying the other one (alh) to see if the ecu was causing the power blip problem!
I have swapped the ecu over a couple of times and seems to me that the alh one won't work!
