Part No is: 06A 919 529B.
I've just been quoted £143.23 +VAT from both SEAT in Bedford and Audi in Hitchin.
Suppose to be quit easy to fit, around 30 mins according to a chap on the Audi forum who fitted it himself.
I'll be ordering mine sometime this week and fitting it myself. Will let you know how it goes.
Hi there, just wondering if you guys had anymore luck with this as i too now have a fault code with mine....
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-10 - - - Intermittent
Andy
Quite straight forward, but don't put any pressure on the probe as it may snap.
Obviously screw the probe into the turbo first and then feed around to underside of intake manifold tray keeping away from the hot side of the turbo. Nip it up tight to avoid boost leaks and don't worry if you can't get it to sit vertical as before because the thread could be slightly longer or shorter.
Is it worth taking it out to try cleaning it?? Or just buy a new one. Also what is the location of it, is it in the back of the turbo?
cheers
Andy
