RobE
I have had my Arosa (1.4TDi) since the end of October; ever since I bought it the drivers side window has had a problem. It opens but not quite all the way down, it stops about 10cm before the bottom and will not go down any further. It closes fine and if you get in the way of it closing the auto reverse feature does take the window go almost the rest of the way down; though I don't want to use that technique to get it open more in case it puts too much stain on the mechanism.
The car had the problem when I bought it and the garage was going to fix it, but apparently when they took the door card off it seemed to be working, then when I picked it up it had stopped again. I was in a hurry for the car so I took it as it was, although did get some money off.
Another issue is that the passenger side window, that previously worked fine, will not open at all now. When you press the button there is a click and then about a second later, if you keep holding it, another click (like a relay) but the window makes not attempt to move.
Any ideas what either of these problems are likely to be? Is it some sort of adjustment to tell the window where to stop (on the drivers side at least).
Thanks in advance.
Rob
Thanks in advance.
Rob
