torquesport
Lets Torque Diesel
Jan 19, 2008
137
Stone, Staffordshire
drivers side lecki window has stopped working but passangers is fine, i keep trying it and it works now and then but then stops and that only once in a blue moon any idea?????:confused:
have you had a look at the electrics dude,same thing happened to mine an i chacked the wiring an it turned out to be a dodgy connecton,an depending on the way its sitting it will sometims work or sometimes not
the connector on my N/S/F window unplugged it self, couple of screws and the card was off. simply pused it back together, and half arsed stuck the panel back on..
Ive got a similar problem, I can hear the mechanism when button pressed, but no movement. Have been told its the regulator
