Electrical gremlins help needed - blower/12v socket/random warning lights
Apr 29, 2021
Hi, hoping someone might be able to point me in the right direction.
On the wife's mk3 leon (2016 1.6tdi) had a load of odd electrical issues recently.
Firstly 12v socket and blower motor stopped working.
Took the motor out, works fine with 12v direct.
fuse had blown on the 12v socket so replaced that.
Thought it might be the controller/resistor pack, swapped for an apparently known good one still nowt.
No codes on vcds
Few days long 4 hour trip and part way through dropped the window and the traction control/abs/headlight range warning lights all came on. plus off ball stuff like winter tyres and cornering light errors (which it doesn't have).
My cousins garage read loads on low voltage warnings and rear left abs error. He swapped the sensor, checked wiring back to abs pump and thought it might be that.
Still suspecting electrics I put a new battery on it and all warning lights went away.
Blower still not working though
Fastforward a couple of weeks and the mrs driving it today, put the rear wiper on, which didn't activate straight away, but when it did all the warning lights came back on again.
I found this thread on here: https://www.seatcupra.net/forums/threads/intermittent-issue-help-please.438169/#post-4723964 which makes me wonder if it's a faulty relay. However, the thread was for the prev model and theres no 373 relay on this one - either on fuse box behind glovebox or in engine bay.
On the advice of a mate who's good with this stuff, left ignition on, plugged a phone charger into 12v socket and removed each relay in those 2 locations 1 by 1, hoping this would i/d the one for the blower/rear wiper/12v socket circuit. However, power to the socket stayed on the whole time.
Anyone know if there's another batch of relays somewhere else?
Thanks!
Apr 29, 2021
Got vcds back off my mate - latest log with error sections:
Friday,30,April,2021,15:29:31:41541
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
Ross-Tech: Home
VIN: VSSZZZ5FZGR009866 License Plate: SEATV3
Mileage: 108266km-67273mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZGR009866 Mileage: 108266km-67273miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 01114012432519090000
Shop #: WSC 00049 770 00124
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 79F93CB0F87B174384-802C
1 Fault Found:
25126 - Databus
U1123 00 [039] - Received Error Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 52 °C
Intake air temperature: 29 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.453 V
Unlearning counter according OBD: 40
CAN status - engine control module: 0
Cruise Control System (CCS): status: Initialization
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 61335000000399
Coding: 20EE8A9224200975007F060641C9240451249000608224F200 410070C002
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 4B95B678E26755D366-801E
2 Faults Found:
4197 - Rear Left Wheel Speed Sensor
C101C 14 [137] - Open or Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 8
Date: 2021.04.29
Time: 15:09:39
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:48
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5F0 907 426 M HW: 5F0 907 426 M
Component: AC Manuell H02 1001
Revision: 00001K09
Coding: 00100104200100001000000000001000
Shop #: WSC 00049 770 00107
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 3467CD849F992A2B17-8060
1 Fault Found:
459779 - Local Databus
U1030 00 [009] - Electrical Malfunction
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:11:33
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 21051510800445
Coding: 030100F40F087300EA000040000F0001000105000000000000 0000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 75E13080D4637323E0-8020
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A1238290415
Coding: 002000
Battery Monitoring Control Module:
1 Fault Found:
66567 - Local Databus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
Terminal 30 power supply: 12.2 V
Terminal 15: On
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 43859E58CA379D939E-8016
2 Faults Found:
20228 - Databus
U1123 00 [008] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Reset counter: 48
Mileage: 108266 km
Date: 2021.04.29
Time: 15:15:31
Motor status: 01
System status: Driving mode
Supply voltage: 11.75 V
Temperature: 27.0 °C
KFC: 4F
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 11.91 V
uAdSensI_SwitchedKl30_xdu16: 11.91 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 48
Mileage: 108266 km
Date: 2021.04.29
Time: 15:15:31
Motor status: 01
Supply voltage: 12.00 V
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 12.08 V
uAdSensI_SwitchedKl30_xdu16: 12.06 V
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 048C000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
1 Fault Found:
13705985 - Databus
U1123 00 [137] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 108266 km
Date: 2021.04.29
Time: 15:09:38
Walone
1,564
430
Near Heathrow
There is a module called an 'Onboard supply control unit' (J519) just wondering if this could be the problem, I think it's the thing that cuts power to various units if the battery gets low, that is only an uneducated guess
Looking at some wiring diagrams it also has something to do with the 'cornering' bulbs and rear wiper motor. ( the motor will not operate if the rear hatch is open)
Reactions: flat4fanatic
Apr 29, 2021
Thanks, that sounds promising, one of the faults that popped up mentioned cornering bulbs. The battery was on it's way out I think so that could make sense as I'd assume the aircon would pull a lot of power. Found a link to workshop manuals so will hunt out that one.
Reactions: Walone
