emisiions
terminator2000
70
Got 1.6 diesel engine and now had letter to say emissions fix is ready to be done.
Anyone had the mod and did you notice anything different
Should I have it done or wait.
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
read up about it, search as much as you can then decide.
i'm well chuffed with my update....works '63 plate Caddy just recently serviced and Emissions done......
68mph speed limiter overwritten [B)]
so i'm assuming if you have a Map on it that too is overwritten?
terminator2000
70
I hear some people are having trouble starting there cars from cold..
Anyone out there having issues or heard the same
propane94
Bearded Ginger
Nov 15, 2012
406
12
Portsmouth
Got the 1.6 in my ibiza, I have noticed a few changes which I will try to explain.
1. Under very light throttle initially, the engine judders a little more as if it down not know what to do, more obvious with cruise control over hills.
2. The throttle response seems sharper in mine, floor it and it picks up better, it used to suffer from rev hang abit, that is gone and as soon as you come off the pedal, it slows down, slightly aggressively I think.
3. The gear change indicator wants me to shift earlier, if you have the auto or if it beeps when it wants you to shift, this could be annoying.
All in all im happy with it, it drives almost the same as before but with "less" emissions.
terminator2000
70
If your fan is cutting in earlier it might tend to lead to EGR valve Problems.
There is no reason it should cut in earlier
EGR valves seem to be going wrong in a lot of cars that have had the fix.
Even VW are noticing a sharp rise in breakdown although denying it is related to emission fix.
