hi there just wondering if any 1 has re-piped and changed there engine bay on a AUQ 1.8t 20v leon intrested in doing mine and would like a few suggestions!
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
With VAGcom you can read the fuel pressure.got the replacment pipes for the fuel 2 day had to get braided ones! did start a thread about what ones you are ment to use but no 1 had any idear! thay go up to 150psi so should be enough! did have a read up and found out that you need different hoses due to it being fuel injected!!
still haven't managed to get (no.3) so shinny been cleaning for ages! did you take the cover off! and if so does it create any probs!!
Going back to the plastics i probably would of left them black. I think your idea of yellow would of been alot better. I think they look tacky red TBH.
