Engine failiure diagnosis...?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
What do ya reckon has caused this then??
Exhaust also never had any carbon build up all the way through the backbox.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Yup, bored also melted and trashed from heat and the rings appear to have melted although it could have snagged on a hot spot in the bore. You can feel a 1~2mm dip at the top where the bores been melting.
Manifold picture aint really turned out but its pretty blue.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Not yet I haven't. Goble they all seemed to read fine is there any other way to check, cylinder 3 is the hottest cylinder on the Cupra.
Is there any chance just running too lean would have caused this?
One thing I supplied was the injectors as I had them from when I was going AM04 and they were brand new in a box. Wouldn't mind finding out how to have one tested properly.
Jun 28, 2001
1,533
duration and quantity i'm talking abouts here get them ANSU tested then youve got a good case to put forward but make sure you number them up
Jun 28, 2001
1,533
Cylinder 3's usually the one that goes tits up. It's usually that rod that goes, which says something about the combustion/knock in that cylinder. I'm not sure what though
ive had 3 motors go on cyl 2
+one complete bottom end destroy itself
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
and look on a jabba mani which cylinder blows straight out into the exit?
#3
blue is running hot..
lean running without doubt..
spark plug on same cylinder still intact?
Fuel pump supplied? Uprated one?
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
They supplied and fitted an S3 pump according to the invoice, and the plug is smashed / melted. What I'm trying to find out is if the mapping is lean as I had said from day one that there was never any carbon build up in the exhaust like there used to be even though it now had a decat.
Also the blueing on the manifold makes me think its running lean, same for the cleaness of the exhaust side on the pistons. The car was running in 5th at WOT when it happened.
Whats always bemused me is when I phoned about the mapping progress they said it had a 7500 limiter, yet I asked for 7800. When I picked the car up it had a 7800rpm limit but never had been mapped again.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Id be right on the phone to Jabba tomorrow if I was you. Might have to get the injectors tested as you supplied them to prove them not at fault but as people are saying if its been running lean then it sounds like either the pump they fitted hasnt been doing what its supposed to or its not been mapped properly. Either way whatever has happened its totally screwed your engine with only 500 miles use!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Lean
its happened before.
5th on WOT confirms... sustained load, its run lean, and the rest is history.
time for a phone call
