Engine Management light on
Kevgrady
420
North East
well...... driving home one night and no turbo at all???? :confused: went out this morning for a drive and then turbo was back :confused: and then the engine management light came on. got it put on the diagnostics and it read "17964 turbo pressure control".
any ideas?
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
17964/P1556 - Charge Pressure Control: Negative Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
