zak
186
london
i realized an issue with my 2.0tdi 140 when i switch the engine off it just shuts down instantly (like drops dead) when it use to gradually turn off. a guy on the Audi a3 forum managed to solve the issue on his by:
"i did pull out the black hose, tried to move the flap, which seems stuck, after that put the hose back on and the motor on the IMF made a loud ticking noise when i switched the engine on for few seconds, luckly i have warranty so had it replaced, now it shuts off smooth again,"
they mentioned something called IMF < i have no idea what that is.
any help would be much appreciated.
http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/145698-engine-shuts-off-weird-way.html
this is the link to the issue resolved.
Sounds like the anti shudder valve but that's designed to give you a smooth engine cut off. The engine is not supposed to run on.
over the weekend i took the car for a spin on dual carriage, after releasing alot of smoke the engine seemed to turn off properly. after EGR (clean/delete) and few other clean outs ill see if the issue remains if so i'll look more into changing valves etc.
thanks for the help :)
