cus
... Vag only!
Feb 8, 2004
1,713
Middlesbrough
www.nemm.co.uk
hey people.
i've got the epc light on, and every time i clear the code it comes back.
i've replaced the brake light switch, no difference.
made sure all the clutch and brake pedal switches are aligned properly.
made sure that the switches are in correctly.. basically as far as theywill go.
ran out of ideas.
16955 P0571 Cruise/Brake Switch (A) Circ Malfunction
is the error i'm getting. :(
anyone know what i'm missing??? orwhat i can check. cheers
id check and make sure all the brake lights are working and their isnt a fillimant shorting out. had that befoe. also check the conection to the throttle body as brake light switch and t/body directly linked. or you could just have a faulty switch?
Possible Symptoms
* Malfunction Indicator Lamp (MIL) active
* Brake Light(s) not working
Possible Causes
* Wiring and/or Connectors faulty
* Fuse(s) faulty
* Wrong Brake Light Bulp installed (21W instead of 5/21W)
* Brake Light Bulp(s) faulty
* Brake Light Switch (F) faulty
Possible Solutions
* Check Wiring or Connectors
* Check/Replace Fuse(s)
* Check/Replace Brake Light Bulp(s)
* Check/Replace Brake Switch (F)
Special Notes
* Brake Light Switches (F) have the reputation of breaking quite often.
cheers forbez. on my third brake light switch... fuses seem okay to me.
will check the bulbs guessing i can get a replacement one from halfords??
my brake lights are still working fine. :(
are the two switches above the brake pedal supposed to touch is at the same time when depressing the pedal???
I have this on and off. But the error I get is
Brake switch - Implausable signal, have replaced lower of two sensors but still re-appears, brake lights work fine; switches are both being made at same travel of brake pedal. Annoying to say the least.
