EPC light on.
sandro881
hi, the EPC light came on the dash today when i switched it on in the afternoon after having already driven it. even though the light is on, there doesnt seem to be any problem with it :s any ideas on what it could be?
thanks!
icemancupra
Newbie
Apr 3, 2006
78
Before you mess about changing it, get yourself some WD40 or maintenance spray, give the switch a really good spray then operate the switch lots and lots of times. This should cure it. then after about 5 times of turning the engine on the ecu will reset the EPC fault. I did it to mine and it has worked ever since, which is about 3 years ago.
sandro881
fixed it by just pressing the brake loads of times and switching off and on :)
wager
if pressing the brake has sorted it I would take it off and clean it and that should do the trick, It clearly isn't broke so why replace it.
mick-fr
Mégane F1 R26..
Dec 1, 2009
2,406
At a Shell garage..
Its the design thats flawed. It will continue to fail after a while, you really need the new designed one to sort the problem.
As per your other thread, if you "bodge fix" cars like "just taking it off and cleaning it" I wouldnt like to buy one of your cars!
