Errr... that don’t look good
Sl1ced
772
397
So wtf.... someone offer some pointers on this. Front left
Sl1ced
772
397
Sl1ced
772
397
The gods have answered!!! Got any info on how to tackle this? I’m waiting on a manual ! Also I think this could be the cause of my knock? Lol
Sl1ced
772
397
Also... I’ve just found a split hose. Comes off the top of the inlet mani and disappears.... what is it
It’s the large long thin one on top. Was split and flapping about by a small black valve under the tip
Rich.T
1,589
928
Id be treating the car to a new driveshaft if its knocking.
Rich.T
1,589
928
Looks like the vac hose to the brake servo.
Need to fix that sharpish!
Sl1ced
772
397
Would that be the complete shaft including joints etc both end?
Rich.T
1,589
928
Yeh, complete shaft.
Knocking is usually the outer joint but in your cars case, it could be either (or both).
Sl1ced
772
397
Hmm. I wish I knew why the price was so different through euro!!! Always worth a shop around. Is it a simple job?
LCR AL
82
49
Only just seen this. Make sure you check the driveshaft is correct before fitting.
I bought 2 driveshafts from j and r for my cupra r mk1. They were the wrong length (1 longer, 1 shorter!). I found out later when it left me stranded outside the local shops!
Lots of back and forth between me and them, PayPal eventually refunded me and they said they didn't have an alternative despite still advertising them for my car.
I used them for parts to repair my original shafts.
Wish I'd checked google reviews before buying! Good luck
Sent from my SM-A405FN using Tapatalk
Sl1ced
772
397
I’ve matched the part to model and engine code so here’s hoping. Plus I had manic fetch me the same link. We shall see did you fit the incorrect sized ones or did they just not fit
Manic172
Dec 4, 2018
1,458
1,616
Hemel hempstead
www.seatcupra.net
I used them.in my saxo race car.. used to run them for 3-4 meetings then bin them . That cheap it's not worth the waiting for them to fail. But that said I done a whole season and testing and stuff on 1 set and they lasted and showed no signs of wear at all
Reactions: Sl1ced
Sl1ced
772
397
Just picked up this before Toolstation shut.
On offer at 16.99 at the moment. Be rude not to
LCR AL
82
49
I did check these were correct for my car also beforehand. I fitted the shorter one first, not realising. This decided to fall out after a couple of weeks. Fortunately at low speed so no gearbox casing damage!
The longer one wouldn't actually fit to bolt everything back together.
Just check the lengths side by side when you fit. They seem to be hit and miss.
Sl1ced
772
397
Will do mate thanks for the heads up!! Luckily I don’t use the car for anything other than my own pleasure. I also had my butyl seal tape delivered for the leaky door, that seems like the most boring job ever haha
