Jun 16, 2013
54
Uk
Cut a long story short Maf got put on wrong way round (i know don't ask) but new one right way round, now I've got the esp light on all the time and no way of disabling it, had the car plugged in and maf sensor was faulty, changed the maf (bosch exchange) and cleared code, but the light is still on after 3days with new maf, the light is driving me mad any advise on what to do next.
Have tried disconnecting battery, but no change
Any help advise would be grateful thanks in advance.
Had my mate check it all over when he plugged it in, everything was in order he said, just confused as to why the light was still on.
does the car run fine? are logs of the maf showing correct?, have you ran a full scan of the car incase something else is amiss?
Car runs fine, had full scan for ecu, abs etc just that light is ennoying and won't go away might take it to vag specialist see what they come up with
:funk:Update problem solved, had audi assist at work Monday plugged the new software in (not vag com anymore more advanced apparently) turns out to be g214/201 sensor on brake master cylinder underneath(both the same sensor) g214 is connected to the pipe that bends, 201 is the pipe that goes straight down. At least he could pin point where the sensors were and give part number (1JN 907 597 B) today fitted sensor and pressure bled system light gone out. (Told my mate to throw away his crap Chinese obd scanner lol)
