Good advice, car is currently undergoing a near rebuild where cam belt has been changed, along with thermostat and water pump, head gasket and head is being checked also. The previous owner or garage had filled it up with gasket repair which has in turn cost me a lot a money to say i'm annoyed is putting it lightly..
tyres are good all round, haven't checked callipers but I will ask the garage to check! not sure about suspension allinment, is it costly? budget is rather low until new year now
I have the relocation kit on mine. At the moment its a good mod. Instead of hot air from the turbo it gets the cold air from the intercooler side.
depends on budget i guess, some people go for a eBay cone, some go for higher priced ones like jr and jetex, i moved my battery in boot and put a huge ram air one in and noticed a good bit of difference like
waiting on my heat shield to be built then ill tidy it all up, putting the valve from the hot side to the cold side, heard it prolongs the life of the valve and puts some colder air onto the engine sure someone who knows more will elaborate
Initial air temperature is the least of your issues given the air will be compressed through a turbo that's several hundred degrees C hot. That's why we have an intercooler.
Thats why the cold side kit works so well.
Hey dude,
I fitted a RamAir Filter last night and the sound is awesome, constantly fluttering when letting off (check out videos on my readers ride).
I bought the filter from ebay, its the 70mm aluminium based RamAir filter for £30.
I also bought a 70mm silicone joiner in white from Boost Junkies, the filter sits on the bottom half of the airbox so the cold air feed still applys
I also remove the bonnet sound proofing for extra air flow and noise
Stage 2 is worth going for btw, 250bhp is possible.
I'm going for the full milltek turbo back system (as I like it), its not too expensive really.
Can't really speak too much about the 1.8T's given I drive an oil burner. But the TDI intake/lower airbox with an S2000 filter gets plenty of cold air.
Gee, have a read of this:
http://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=318797
Might give you a few ideas - remember it's only 15 quid for the filter.
