B47t0n Active Member Nov 6, 2010 161 0 Nov 11, 2010 #1 Will et 42 offset alloys fit on a seat Leon tdi without any mods ? Thank you
B47t0n Active Member Nov 6, 2010 161 0 Nov 11, 2010 #2 Ok so I've found out the offsets for the Leon are 35 to 38 So would 5mm spacers all round do the job ? Which would make it et 37
adam cupra 20vt Built Not Bought. Mar 31, 2005 6,155 2 Mud Hut Nov 11, 2010 #3 It all depends how wide and big they are, what size tyres are fitted, what type of suspension you have and how low it is. And they need to be 5x100 with a 57.1 centre bore
B47t0n Active Member Nov 6, 2010 161 0 Nov 11, 2010 #4 there inovit torque multi-fit so there 5x100 and 5x112 18" with 215,35,18 tyres 18 X 7.5 on stock suspension atm Last edited: Nov 11, 2010
Fl@pper Back older greyer and less oilier but always hope Jun 19, 2001 12,366 24 Gloucester Nov 11, 2010 #5 as said above and every time a similar question is asked - the offset means nothing without knowing the width of the wheel these may help explain and work it out http://www.seatcupra.net/forums/showthread.php?t=225813
B47t0n Active Member Nov 6, 2010 161 0 Nov 11, 2010 #6 from using the calculator with standard alloy sizes of 7 with et 38 and after market with 7.5 with et 42 is says the inner clearance will be 10mm less and will extend just a further 2mm wil the 10mm less clearance be a problem ?
