yeah - i saw that. i was hoping that there was a built-in aerial rather than having an external one but i don't think anyone has been able to confirm this ?
i've got the saloon anyway so i may not even have the aerial built-in ?
basically, when you have autodab switched on, it overrides the scroll controller on the steering wheel until you switch it off. everything else on the main unit itself and the volume scroll controller continue to work as normal until you switch autodab off again e.g if you have autodab switched on and then switch to media and try and use the scroll button to switch tracks on your sd card, nothing happens until you go back to the radio and switch autodab off.
not sure about the satnav question - i wasn't aware that the routing would change depending in response to traffic info as i don't use the satnav that often to be honest.
