hugh_
87
Kent
I need to replace the rear brake discs on my Exeo ST, does anyone know what sizes discs they will be? It's a very late 2009 (prob MY10) SE spec if that makes a difference.
If no one knows I will have a measure this evening and post up.
For reference my late 2009 (register 31/12/2009 so prob MY10) estate 2.0TDi 143 SE spec has 288mm front, and 245mm rear.
Glad you got it sorted hugh.
Just for reference also, I included it in my thread but it'll save someone searching if they come accross this thread first..
In my case I have the facelift 2012 2.0TDi CR170 Sport Tech ST, so I assume all the Sport Tech 170s are the same, and the sizes for that is:
Rears are 255mm
Fronts are 312mm
Hi,
Changing brakes for a pal at the weekend. Do you need a special spline tool for removing the rear discs like some of the other newer VAG models?
Any guides out there? (A4 etc?) Fairly comfortable doing brakes, just would like to spot any pitfalls before I start!
TIA!
