stezo2k
Anjuna Monkey
Mar 15, 2008
2,794
Dudley
Hi guys, whenever i start my car from cold i'm getting quite a squeak from the fan belt, wd40 helped but it hasnt fixed the problem, can they be adjusted?
If i need a new one can anybody advise me where to get one on the net? thanks
________
Vaper Genie
i'm glad somebody replied :) i was just about to bump the thread, looks like i need a new fan belt
tbh for me its when i havent started the engine for about 12 hours or so, doesnt matter whether its in gear or not. it does go away after 5 minutes but its embaressing when my neighbours walk by in the morning :p
anybody know where i can order a new fanbelt online? thanks
________
Wanna_Play_Hot
aha! i have the same issue, have you got yours replaced and how much did it cost? what are the consequences of not getting it replaced as im skint...
i thinking you mean the auxilery belt not a fan belt, as all cars use an electric fan now. From what i recall i got mine replaced when i had my timing belt change and i remember it was £15-20.
You seeing any cracks or any sort of wear and tear on yours?
If you're talking about the aux belt, it could be the tensioner. £60 parts and 5-10 mins to replace if it is.
The aux. belt or V belt as VAG say will squeak after a few years, they will have a glazed look on the inside off the belt due to slipping and the only cure is to change it. Easy to change yourself for about a tenner. Sometimes the tensioner will need changing as well. The timing belt is called a Toothed belt by VAG.
I had mine replaced a little while back under warranty. That solved the problem for about 10 months. But now its doing it again. Really bad when the engine is cold. I was going to try a bit of WD40 the weekend but sounds like that didn't work. Any other ideas are welcome :shrug:
The only cure is to change the belt and to be sure change the tensioner as well.
WD40 is not a good idea IMO as from as far as i know, the WD40 will gradually degrade the rubber on the belt over time making this worse.
yeah changing the fanbelt and tensioner fixed my problem, sounds much nicer now :)
hello mate can you describe the noise and its habits. i'm trying to diagnose a strange sound from my car. kindof intermittent warbelling sound. like a cute fuzzy extra terrestrial animal would make.
all i can describe is a squeaking sound which sounds more mecanical than like an animal, i could hear it louder than the enginge. i only got it when i started my car from cold, after 10 minutes it was fine. if you upload a sound i can tell you if it sounds like it
________
Ford maverick specifications
