Badger Active Member Dec 2, 2012 2,643 7 Newcastle, Staffs Dec 22, 2012 #2 VAG Error Code: 16621 EOBD II Error Code: P0237 Fault Location Manifold Pressure / Boost Sensor (G31) - Signal too Low Possible Cause: Malfunction Indicator Lamp (MIL) active. Manifold Pressure / Boost Sensor (G31) Power Supply faulty. Manifold Pressure / Boost Sensor (G31) faulty. Possible Solutions: Check Manifold Pressure / Boost Sensor (G31) Power Supply. Check Manifold Pressure / Boost Sensor (G31). "Obtained" from another site! Last edited: Dec 22, 2012
ibizacuprabates Active Member Mar 13, 2012 277 0 hull Dec 22, 2012 #3 Ye idles fine when I hit a bump it misses I'm taking bumper off 2moro to check it but ill replace the map sensor mon
