SeanCorky
BMW E92 335i M Sport
Sep 4, 2008
809
Liverpool
Code:
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 998000005283CC7F00068F0F6008DF86107C00
   Shop #: WSC 06402 785 00200
   Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Shop #: WSC 06402
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Component:       NGS n.mounted
1 Fault Found
00893 - Switch for Trunk Handle (E234)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 24794 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:02:26
Any idea? Looks like a switch for the bonnet?
sorry to dig this up. Just got this code now. This its the boot handle!? The S logo, mine stays horizontal now rather than lie flat... not sure what im getting at but wondered if you still had this fault code or worked out what it was!?
Hi, what did you do about this, my daughter's car also has this problem? Could be a return spring failure or just stiff - daughter hopes its a FOC warranty repair!
Thanks, for that reply, but, it feels like its not got any return "effort" - ie spring. This is turning out to be roughly a copy of what happened with her early 2002 Chill 6K Ibiza, two models on and Seat still using "proved to be faulty" designs that are cheapened versions of what VW used 10>15 years ago. Car has been in for its second service today but I have not heard what the fix was yet.
To be fair I got a brand new boot handle off eBay and replaced mine, though I did strip and paint it first.
Ah, that old game, well my wife has a 9N Polo in silver, and its hatch handle corroded badly after a couple of years or so (salty muck getting "hovered" up due to shape of Polo rear), then a painted one appeared on ebay - brilliant, I bought and fitted it, job done. Then a couple or so years later same thing happened - looks crap but as ebay is now only selling primed ones I'm not too interested. I think that VW's supplier of that part had quality problems round about mid 2002 and her car ended up being fitted with a substandard part as did others and some ended up being "binned" onto ebay. Seems that this was only a problem with silver 9N Polos of that build period.
Had similar issues with both my silver 6N2 Polo GTI and a MK4 golf of similar age. Keep us posted
Car has now been in for its second service, new hatch handle assembly on order to get supplied and fitted FOC it seems - as I would have expected as its still under warranty.
