redline69
help need advice on some fault codes on my seat leon cupra r
fault codes are 17704/p1296 and 17705/p1297. car feels slow,also sometimes when u start it up it idles at 3000rpm.any 1 got any ideas thanks
17704 thats the temp sensor or stat gone or may be both. also check for a air lock. 17705 is a boost leak between throttle and dump valve. check your dump valve and check for split hoses.
thanks mate,willl have a look later.might change dump valve anyway as still standard 1 on it and car has had stage 2 remap so may bennefit better dump valve. where is the most likely place 2 find split hoses? thanks again
what is the best dump valve 2 replace the original 1 with?:confused:
just tried looking for split hoses,but dont know where 2 start looking. Anyone got any idea which are the most common hoses 2 split. THANKS:D
not yet mate,just thought i would try eliminating hoses first,before spending out on dump valve
You really need an uprated valve on a stage2, for all you know the boost leak could actually be the valve as they quite often fail.
cheers mate,will get 1 next week and let u know if it sorts the problem. also still got standard TIP could this be causing problems with stage 2?
what modds you got to run a stage to? cos alot of this should have been changed before the stand tip is pants it fails at 5000 rpm and you really need to upgrade these asap
I bought the car off my mate.He had done remap but left everything else standard! it was pushing 286bhp when i bought it,doesnt feel anywhere near that now though:(
